CAR SHUTS DOWN WHENEVER
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
DMSR
Car: altima 2002 se
MY 2002 ALTIMA SHUTS OFF FOR NO REASON,IT FIRES RIGHT UP NO PROBLEM,I PUT IT IN THE SHOP THREE TIMES SO FAR AND THEY CANT FIND THE PROBLEM,I LET THEM KEEP IT AND DRIVE IT FOR 8 DAYS BUT STILL NO CODE FOR THEM TO CHECK. WHEN I GOT IT BACK 4 DAYS LATER IT SHUT OFF AGAIN ON THE INTERRSTATE!! CAN ANYBODY HELP?
Modified by DMSR at 3:35 PM 11/14/2006
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
DMSR,Welcome to NICO. That is an interesting problem. Did you check your wires to the battery? I would start there first.
DMSR
Car: altima 2002 se
YES I DID ,JUST PUT IN BRAND NEW BATTERY,NOT RELATED BECAUSE IT WAS DOING IT BEFORE THAT,I PICKED IT UP TODAY 11-15-06 AND WILL SEE WHAT HAPPENS NEXT
Lazyron007
Car: Nissan Altima 2.5S
Did you bring your car to a dealer for the recall it had. Something with the crank shaft senor which makes the car turn off in the middle of driving. You should have recieved a notice in the mail (i did for my 2003 altima).
mfiazzo
Car: 2003 nissan altima
It is the Crank Positioning Sensor. The same thing happened to me. It is a recall and it should be fixed for free.
LA02MAX
Car: 2002 6-speed maxima
mfiazzo wrote:It is the Crank Positioning Sensor. The same thing happened to me. It is a recall and it should be fixed for free.
unfortunately it's only covered if you're under the 5 year 60k mile powertrain warranty...so if your car has over 60k miles and you don't have an extended warranty, I'm afraid you're SOL and will have to pay to get it fixed...not sure how much a CPS costs but it's not that labor intensive, which is good...
Lazyron007
I didn't have to pay but i remember when looking at the reciept that it was only like $130 or something like that. Definately no more than $200.
robert_townsend_86
Car: 2005 Nissan Altima 2.5S
I have a 2005 Altima and it does the same thing. Shuts off whenever. I replaced the crank sensor and did not solve the problem. Stilhttp://forums.nicoclub.com/zeropost?cmd=reply&id=2193423#zer...423#l doing the same thing!
wfo_1974
There is also a ecu reprograme that needs to be done along with the above mentioned recall for the sensors. i would also check that your mass air flow meter is pluged in good and make sure your air intake duct work is installed good and tight do you still get fuel pressure and spark when it does die and will not restart?
Return to “3rd Generation Altima Sedan (2002-2006)”
