rawr007 »
https://forums.nicoclub.com/rawr007-u162705.html
Mon Jun 14, 2010 7:07 pm
hey guys,
first the car is a 2004 G35X stock no mods,
yesterday i replaced my stock airfilter with the k&n drop in airfilter, and i had the sensor already off the airfilter and told my gf to let the car roll back a bit so i can have better access, what she did is started the engine for like 5sec. and turned it back off after i yelled at her..
so i replaced the air filter, put everything back together and started the car and the serve engine soon light came on. so i drove to the next auto parts store and the error codes said:
P0102
P0102 Pending
P0113
after research i saw that lots of people had these errors after replacing the air filter and said ecu reset or just drive around for couple days it will turn off automaticly.
so i did the ecu reset over night, put the battery back on this morning and started the car, everything was fine. So i drove around, parked the car and came back after an hour to start the car and now i have following problem:
i start the car and then it cranks up and all of the sudden the rpm drop to 0 and the car shuts off and the serve engine light comes on again.
if i start the car and if the rpm go down to 0 and i hit the gas peddle only once or many times doesn't matter it stays on without a problem and no engine light.
so my questioin is,
is it normal after a ECU reset maybe the car has just to get adjusted again
or did i brake any sensors? i looked it up and the mass air flow sensor is 300 bucks
then i tried to reset the Accelerator Pedal Release Position Learning, reset the Throttle Valve Closed Position Learning, reset the Idle Air Volume Learning (Throttle Position Learning)
nothing worked so far, i just dont know what else to do..
