Sounds to me like the driveshaft center carrier bearing. Easy to check.
1. Jack car up and make sure it's stable on the jack stands, as you're going to be under it.
2. grab the driveshaft near the carrier bearing and try to shake it.
If it moves at all, it's bad and needs to be replaced. Instead of replacing the bearing, for about double the price, you can eliminate the bearing altogether by swapping to a one piece driveshaft. I highly reccomend shaftmasters. Just recieved my shaft from them for my 5 speed swap, and the quality is absolutely top-notch.
BTW, Thanks for searching!
