Car Shaking and Vibrating
NoStickDrift
Car: 1989 240sx
Hey all, my car has been shaking a little bit and vibrating a bit also around idle but the rpm's are constant. Is this due to the motor or transmission mounts or is somthing else going on? Its a 89 with 152k so I figured its gotta be one of those two. If anyones got soem suggestions let me know.
zippitta
Car: 1990 240SX HB
Other than the shaking, does the motor run alright. Does it seem to have no power? If the motor is working fine then I would say check your engine or transmission mounts like you said before.
Axel Grungy
Car: 2001 G20 5spd
does the motor sound really rough while its shaking??
seyath
Car: 2004 Maxima SE, 6sp, black leather. 1991 240SX, 5sp, grey leather.
This is going to sound really stupid, but I'm assuming that you checked if your car was aligned and your wheels are balanced, right? Because before you invest in getting new mounts, you might just fix your problem.
HashiriyaS14
Car: '95 Nissan 240SX
'08 Honda Accord
'08 Honda NPS50
'03 Kawasaki Ninja 250
'60 Honda Super Cub
seyath wrote:This is going to sound really stupid, but I'm assuming that you checked if your car was aligned and your wheels are balanced, right? Because before you invest in getting new mounts, you might just fix your problem.
Could also be your tires, but if it's really vibrating a LOT, my guess would be alignment.
NoStickDrift
Car: 1989 240sx
Its not the alignment. I work at a sears auto and all my alignment and balancing is on the dot. It will shake when its just sitting at a stop light or when i let the car warm up in the morning. The motor doesn't sound like its having a problem, it purss like all our KA's do :P
naed240sx
Car: .....
Hmm, my car has a similar problem, but its not irritating. I always figured that it was just the beefy 2.4 l 4's natural rumble. kinda like a big v8 or something.
NoStickDrift
Car: 1989 240sx
Its to that point where it is bugging me, I dont mind a little bit, but it has been a little worse latly, specially when iam chillin in a drive threw to get my big *** somthing to eat.
HashiriyaS14
'08 Honda Accord
'08 Honda NPS50
'60 Honda Super Cub
When I broke an engine mount in my Prelude, it would violently jerk the car on start-up, and shake a fair bit whether moving or not, so long as the engine was running.
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
my dads car does that, ...but it's an auto and an entirely diff problem from yours I believe.
naed240sx
Car: .....
have you opened the engine bay and looked for engine rock? I would try to find somebody else with a 240 and compare.
