car shaking 55-60 mph
Vedoman
Car: 90 240sx s13sr20det
my car vibrates like crazy at 55- 60 mph. the tires on the front are pretty old and im about to get new ones mounted and balanced but im not sure if that is the problem. i think my motor mounts might be going bad there is some play when i try to move it around with my hands. any suggestions
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
if ya have stock mounts there will be a slight play if ya put your body into it..look under bright light at your mounts and see if you have broken or crack'd rubber at the mount area..if so that could be your issue...if its not your mounts..it could be your tires or something worse..balljoints/alighnment..and id sugest to get it fix'd as fast as possible..for safty..good luck.
Vedoman
My car doesn't pull to either side and the tires wear pretty evenly. So I don't think it's the alignment. Is there a way I can test my ball joints or do I just look at the bushings? If it was the motor mounts, shouldn't it shake at a certain RPM in every gear? Not just a certain speed?
Axel Grungy
Car: 2001 G20 5spd
willing to bet its your tires....hopefully.
cleopp3
Car: 93 nissan 240sx
did ya check the rack and pinion set up? does it do it when u acelerate?
Vedoman
the rack and pinion seems solid and it doesnt shake during accelration only at 55-60 mph
articzap
Car: 2014 F150 FX4
Tires are out of balance. I had this problem. Your motor mounts will not cause a vibration at only a certain speed.
snake240
Car: 92 hatch SR20DET
id say tires. have you checked air pressure. if they are too low it can cause shaking.
TonyStarks29
Car: 1994 Nissan 240SX Convertible w/ SR20DET
Tires, it happend to my on my dad's truck becare full it sounds like its ready to blow at any time
mtlotslove
Car: 1989 240sx
mine is doing the same thing. i surely thought it was my tires being out of balance (which they were) but i'm pretty sure it's my rack now.
mouse2651
Car: 1990 240sx
the shaking is cuz your rims are out of ballance that happend to me too. and stock mounts have a slight play so thats nothing to really worry about
Vedoman
how can i check my rack and pinion and mouse i like that sticker where can i get some
Piper
Car: 96 240, the new toy.
93 Vert, gave to my bro... for now,
91 HB, brother totaled,
27 other 240sx's in total, all gone now!
dont worry about your rack and pinion. its your tires, i will bet my life on it. the only time a car vibrates at a specific speed, its the tires and 99% of the time its at 50 to 60 mph. go to a shop and have them check your tires and rims. something is off.
liquid_cool
one last thing to look at allso......shocks...if you have a shock that has faild then it will make your tires bounce like a golfball at higher speeds (depending on road condition)....this is a posibility..just another idea of things that go wrong....keep us posted bro.
Vedoman
yeah i thought about that but my skocks are pretty new and feel good the car dosent bounce when i push down on it a couple times. but i did put lowering springs with oem shocks that might have wore them out, all four wheels are out of camber now. im gonna get new tires this weekend and get them balanced and aligned, ill see what that does and keep you guys posted.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
Vedoman wrote:yeah i thought about that but my skocks are pretty new and feel good the car dosent bounce when i push down on it a couple times. but i did put lowering springs with oem shocks that might have wore them out, all four wheels are out of camber now. im gonna get new tires this weekend and get them balanced and aligned, ill see what that does and keep you guys posted.
yeah, dial all the wheels balance, alignment and then see if it persist. im betting it will be all good.
Vedoman
got the wheels balanced and no more shaking.
nevertheless
Car: 1993 240sx hatch
1995 Nissan D21
showing some orange s13 love, no longer 4x4http://forums.nicoclub.com/zer...age=1
