car shakes when i press the brakes
kylekinnamon1989
Car: 90' Nissan 240sx SE/ SR20DET
when my car is just idleing it idles good, but when i press the breaks it starts to shake and the rpms go down.. THIS HAPPENS WHEN I AM STOPPED! so therefore, it can not be the brakes, rotors, calipers or soforth. i think it might be my brake booster vacuum line? please help
Dunky Kong
Car: 89' SR20 240sx
It sounds like what you said could be true about the brake booster but how much do you push on the brakes before your rpms drop.....Maybe tail lights are drawing to much current?
jaimecollins
Car: 93 240sx Coupe. Silvia Conversion with 96 Dual Cam Engine.
do you idle in neutral or with the clutch pushed in?
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
kylekinnamon1989 wrote:when my car is just idleing it idles good, but when i press the breaks it starts to shake and the rpms go down.. THIS HAPPENS WHEN I AM STOPPED! so therefore, it can not be the brakes, rotors, calipers or soforth. i think it might be my brake booster vacuum line? please help
check your grounds! i had the same problem. my car would try to bog out when i pressed the breaks. all my gauges would go crazy too. i just bought a few grounding cables from autozone and it solved the problem. goodluck!
MySXisSlowerThanUrs
Car: Toyota Mr2, Nissan 350z, 89 Piggy 240sx
Whatever it is, it seems like its taking power from the engine to drop the idle so its inconsistent, brake booster possibly
emo_tactical9
You should probably actually read the thread before responding. ^^^
Cone Junky
Car: S13 fastback
BMW e46 328i
emo_tactical9 wrote:You should probably actually read the thread before responding. ^^^
Why start bad habits now?
Check for vacuum leaks, although if it's inside the booster, it will be a little tougher to diagnose.You can try plugging off the engine side of the booster hose and see if the problem still occurs. If it does, the diaphragm in the booster probably has a leak. If the problem still occurs start checking for electrical problems.
kylekinnamon1989
Dunky Kong wrote:It sounds like what you said could be true about the brake booster but how much do you push on the brakes before your rpms drop.....Maybe tail lights are drawing to much current?
the harder i push it the more it shakes
emo_tactical9
Strange thing, after i read this thread, my car started doing the same thing. Mine gets worse if i pump the brakes real fast. Does yours?I looked at the wideband while it was bogging, it was maxed out LEAN.I hooked up ecu talk and my injector PW didn't change. Strange that the ECU wouldn't try to fix it.
Either way, i'm pretty sure it's a vacuum leak. I got old, crappy hoses.
