goofynick6 »
https://forums.nicoclub.com/goofynick6-u13220.html
Fri Sep 03, 2004 7:34 am
It does have constant power, I rewired it last week so it did. I tried to set my timing, but I can't set my idle yet thanks to my Mustang TPS (using mustang tb) only going to .57 volts as a minimum voltage. I think the timing is at 15, it pulls really hard the first 10 minutes of driving, then as everything (oil, coolant, intake, underhood area) gets hot, it seems to be pulling timing a bit. I'm thinking about adding an oil cooler and another fan to keep things cooler or something, the power loss is very very noticeable though.
Does anyone know how to add something like a resistor to the tps output signal to drop it 1 volt from .57 to .47? I think a resistor might do it, but not sure if it would keep the voltage linear as it increased.
Thanks!
Nick
