car sat for 9 years in garage..now what?????
mike555
Car: 1992 maxima se
ok..here's the deal...bought a 1992 maxima se with 140,000 miles on it..it's been sitting for 9 years in an unheated garage in n.y. now it looks like the previous owner had taken good care of it. i have all the records on it..now my question is other then change the fluids ie. oil..coolent..transmission(5 speed btw)..should i siphon the gas out???..and what about turning it over?..should i oil the pistons?..if anyone can help me i would appreciate it!!!..this car looks like alot of fun...thanks again...mike
ard
Car: 1989 200sx ca18det
put few ml of oil into cylinders through spark plug holes. change oil, oil & air filters, spark plugs, pump out old gasoline, fill half a tank of the highest octane (not 105) you can buy and then try to start.god luck!
also check all the fuses, and get a new battery.
it was a pain in the arse when i was starting sr20de after 12 months
Q45tech
Budget and replace every single rubber hose, bushing , seal, and weather strip every single tiny one!
sdcaller
Car: 2004 Titan LE
Good replies.
Add: replace plug wires; check distributor for cracks - prepare to replace at least dist. cover
BWSan Diego
