KantGo55 wrote:OK, everything should be dry now and problem still exist.I changed the oil from 10W30 to 5W30, would that matter?
Your change in oil has no effect.
The ignition wires may be cracked so there may be trapped moisture. Also remove the distributor cap and check for moisture.
Make sure there's no moisture on the fuel injector harness connectors.
Check the harness connector for the crank angle sensor that's on the distributor.
