car runs like poo after installing stuff
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
I got tune chip from emance and installed it in as it said in the instructions, nothing too hard, and it was pretuned with sr injectors and a N60 MAF. I installed everything and the car runs like poo. It idles super rough and stays below 500 then stalls if I dont hold the pedal down. Also I think its running really lean because white smoke comes from the back but it doesnt smell like coolant. If I rev it up it is very hesistant and feels like there is no power. I just need some insight on this, If anyone has any ideas please share because I am out. I thought it was a vacuum leak but I couldnt find any
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I am not 100% of my answer but I would say EVERYTHING E-mance sells is trash, Consult Connectors, ROM tune chips....
I can only get my Consult Connector to work with a certain ECU so I will have to trash the connector for his lack of communication.
If you recently bought the chip and paid through PayPal then get your money back.
Did you install the ROM chip correctly though?
-RJ-
yeah i followed it to the line, it wasnt hard at all. I thought it was a vacuum leak, so i found a small one and replaced it but its still doing the same thing. I also hear ticking noises coming from the head
im going to pull the rail and see if the injectors are leaking.
cmkelly
Car: 1992 Nissan 240SX Vert
2006 Acura TL
2001 Nissan Pathfinder LE
1996 Toyota 4Runner 4x4
Is it difficult to reinstall the original chip and see how it responds? If it was running fine before the "upgrade" and fine after you reinstall the original at least you can rule out catastrophic things like a blown head gasket, etc.
-RJ-
i pulled the fuel rail out a bit and checked for leaks, now it wont go back in sraight D: ARGH
Klits562
Car: white s13 coupe
-RJ- wrote:i pulled the fuel rail out a bit and checked for leaks, now it wont go back in sraight D: ARGH
make sure the seals for the injectors aren't damaged and try gettin a little WD40 on them before sliding the injectors back on.
Was the n60 maf a new thing you installed or was it on they're previously cause it sounds like a bit of bad maf sympthoms.
-RJ-
there were no leaks in the injectors, the problem im having is the rail itself isnt evening up. I thought i bolted it right on the car and i turned the ignition to "on" and i saw a puff of white smoke come out of cylinder 4. When I took a closer look the injector is slightly to the right of the seal and i cant get it to even up
Eikon
Car: 71 240z, 93 Supra TT
From what I've heard, the best way to tune and fix an e-mance system is to completely uninstall it and throw it in the garbage.
-RJ-
Blah, i read a lot of good things about their stuff. Why is it now that everyone is telling me its crap. Anyway that white smoke isnt anything bad right?
-RJ-
hmm turns out i didnt install the chip right. i tried pulling codes but the little led just stays on
-RJ-
I got everything fixed and the car runs great. It feels so much more responsive now
