CAR Runs great but "CHECK" light is on...?
w00t_Masta
The check light is on, but i can't remember if it's always been since i bought it or what... I checked oil-good, sparks-good, runs well. But i like many others have the problem w/the Battery/Brake light being buggy as hell...
TrueSlide
Car: Stuff
have you tried your oxygen sensor??
Nismo_Freak
Car: 89 Nissan 240SX
I guarantee you its an 02 sensor... look for a code 33 on your ECU read-out.
33 If I remember right...
GodDrivesA240sx
Car: 1995 Nissan 240SX
your cat's prob rotted away and the 02 sensor is sending a bad signal to the ecu. That is if you are 95 and up
(yeah pretty much what those guys said. however, chalk up another post for me)
w00t_Masta
Well, My car is a 93... and i have no clue about the "read-out" on my ECU. If it is my O2 sensor, do i jsut need a new one.. or is there a fuse for it or somethin?
TrueSlide
Car: Stuff
just buy a new o2 sensor from like advance auto, get the universal its like 17.99, should be the fix, im 99.9% sure thats your problem :)
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
where is the o2 sensor located.
TrueSlide
Car: Stuff
It should be located on the exhaust manifold.
nautybynature
Car: interests....definatly girls, hanging with friends, finding better things to do than i did yesterday
oh and if you cut a knuckle while fixing your car, heat up the engine and cauterize your knuckle on the manifold - stops the bleeding. :eek: no shat.
just playen
w00t_Masta
Well i posted about the ECU shiat on the Technical part of the forums. And i finally know wtf is going on. So i'll check the ECU and prolly just replace the sensor like Truslide said. Prolly the reason why i am runnin lean.. i think it's lean anyway.. My sparks are pretty new and aren't as white as they should be. You guys are rad. You make workin on my car myself 100000000x easier.
Nis240sanSX
Car: cars, motorcycles, music, playing guitar
In my area, if your check engine light is on, they will check your ecu and tell you what the problem is for FREE, they probably do it everywhere, you should check.
