youre right.mechanically, its in the perfect place. up high on the block, centered, on the intake side (not much excessive heat)s13sr20detsilviastityper wrote:what is the best way to go about redoing the wire for the knock sensor/hooking it up? ?
where can you get at it ? from the bottom??
i need to redo mine but it seems impossible to get to from the top without removing anything.. i cant even see it ..
thanks! i will try it out tomorrow, picking up some shielded wiring todaytyrannix wrote:youre right.mechanically, its in the perfect place. up high on the block, centered, on the intake side (not much excessive heat)
but, with that goes the impossible factor, get a 10 year old to reach in there. its the only way (if you dont have kids, youre out of luck, as it would probably be considered 'wierd' to borrow somebodys kid to reach a sensor
on the plus side, if you somehow get the plug disconnected from teh sensor (i managed it eventually) then just use some shielded wire
i reccomend putting a quick connector farther up on the harness as well (remember to have 2 connections, one for signal, one for ground on teh shielding)i did it, and it makes life easier if you want to pull the engine again
CJ
EDIT> and yeah, jack your car up (shop lift FTW) and roll under the car, behind the engine. with a shop light, youll be able to see the knock sensor. look for green. above the oil filter and a little back, thats it. and its a bish to get the connector off (out of the 3 ive tried, ive broken 2)
CJ
