CAR RUNS BAD AFTER REACHES NORMAL OPERATING TEMP.
KPIERCE70
Car: 1993 J30T
I HAVE A 93 J30T. AFTER IT REACHES NORMAL OPERATING TEMP IT WILL NOT RUN OVER 2000 RPMS. I DID A TUNE UP, WHICH I REPLACED THE PLUGS, AIR AND FUEL FILTERS AND FUEL PUMP AND STRAINER.STILL DID NOT HELP. THE FUEL PRESSURE IS 30 PSI. I HAVE NO CHECK ENGINE LIGHT ON AS WELL. I HAD THE CATS CUT OUT AND INSPECTED, THEY WERE FINE?
WHAT SHOULD I CHECK OUT NEXT? :
float_6969
First of all, are the caps nessisary?
Secondly, 30psi for the fuel pressure is about 6psi too low. You probabaly need a new FPR.
Lastly, try getting a new engine temperature sensor. I think they're like $25.
NeedCAforS13
Car: CA swapped S13 coupe
Moved ya to the J30 forum... not sure why this was in CA18, but ok.
Sean
driverdriver
Car: NICO's longtime resident Canuck!!!
You may need a new transmission rev sensor.
