PMan_S13 »
https://forums.nicoclub.com/pman-s13-u3715.html
Thu May 20, 2004 12:19 pm
I've made a post about this in the Tech section. Hoping to find someone who has come across this problem, and solved it.
Rebuilt '91 KA-t, 8.5:1 compression, 370cc injectors, s-afc2, recirc bypass valve, no emmissions junk, nothing else would matter.
After some other annoying problems I've solved, the motor will start and run fine. The problem is it is idling way too high (2k) when it is hot or cold. Checked everywhere for any type of leak, nothing. Since all the emmissions are gone, there is not a lot of places for vacuum to leak out of. I've tested all with a vacuum tool, all held pressure pretty well. Can't really check the timing since it never gets lower than 2k. But at that speed it is at about 25-30 btdc, which is close enough to not matter to idle, I think.
Now it may seem like I just need to turn down the aac, but the other problem is strange. If you rev it up at idle and let it settle. It will decel down to ~1400 and then stop and something changes. It then runs very rough, no stumble or anything, just roughness. This lasts about a second at most then something changes back and it speeds up to 2k again.
I assumed this was the ECU pulling timing. Timing gun shows about 10-15 btdc when it is rough. It then changes back. So I pulled back a lot of timing, as far as it goes without moving a tooth. It starts and idles at ~1450. Revs up and idles back down no problem. Check the timing 5 ATDC. Runs really rich, no power, kind of unstable. But when I switch it back it does this cuttting out again. Once again, it doesn't go rough until it has idled down that far. It doesn't cutout while I am revving it up. So now I guessed that it must be off a whole lot of timing and the ECU is pulling timing on startup. Negative ghostrider, ignition timing is spot on. If you disconnect the TPS it revs to ~2700. On reconnect it does the roughness at 1400 again and then goes smooth to 2000 as always. Don't want to drive it unbroken in wiht it all messed up, but I have driven it a mile or so. Drives just fine. I got it to act even weirder just a little while ago. Revved it slowly to 3500 and let go. It did the roughness as suspected, then revved slowly to 2250 at which point it went rough again. It did this like 5 times, I finally blipped it and it stablized to 2000 like before.
Frankly I am at wits end with this darn car. Here's a list of things I have tried.. Someone PLEASE help...
-Reset ECU, ->nothing significant-Reset S-AFC2 (Motor in not broken in or tuned yet, -27% across the board) ->nothing-Tried pinching Air regulator, too remote, so I disconnected it -No change when warmed up.-Checked timing ->good-AFM is good. Just got newer one.. old one made idling impossible (bad element)-Pinching main idle line will make it idle down, even kill it.-checked TB closed voltage -> 0.5v-Replaced 02 sensor ->Seems to work, runs a little on the rich side, but can be easily set correctly with the AFC (I left it at -27%) which doesn't change much except the smell.-Hicas needs to be bled, or at least the little light is on. Doubt that makes it run differently, but might as well mention it. PS level is good.-oil level is good-engine light works, but doesn't flash.
That's all I can think of at the moment. Again, someone help.. I'm really tired of driving a Neon.
