KornFlakeZ »
https://forums.nicoclub.com/kornflakez-u193168.html
Sun Jul 22, 2012 5:57 pm
So basically my 90 n/a started running on 5 cylinders. The cylinder thats giving me problems is cylinder 4. I checked injectors, spark plugs, coil pack, wiring and they all seem to be fine. I also checked the PTU harness since its known for them to come loose and it seemed fine. I dont know where to go from here... i will probably check ecu codes and see if i get anything... any ideas of what could be causing the problem?
