Car running like crap....need help
blatour
Car: S13 coupe
All summer it's been running very nice, purrs like a kitten, roars like a lion, etc.But I haven't driven it for a good week when he had our big cooldown this last week(going from 70's to 50s, around 35 one night). I went to start it last night to go the weekly night meet up in our city, and it wouldn't idle at all. So I unplugged the SAFC, and boom idled great. But you can' go over 2500 with it unplugged. So I let it warm up, plugged the safc in, and boom, dies immediatly. I'm thinking WTF? So I start it up starts right up, but I have to give ALOT of gas to keep it running untill I get it over 2000 rpm. Any thing after 2k rpm, it runs perfect, like it should. The SECOND it drops below, it bucks and trys with all it's might to die. I'm baffled. Any idea? Everytime I get to s stoplight, I have to tap the gas quite a bit, or else it will die.
blatour
Car: S13 coupe
Anyone?
Naloos13
Car: 1989 S13
a friend of mine killed his when he jumped his car and it would do the same thing...
blatour
Car: S13 coupe
I've tried resetting the ECU, that did nothing. Could it be fuel issue?
blatour
Car: S13 coupe
bump
blatour
Car: S13 coupe
bump
drftsx
Car: 90 240sx(sr)
same thing happen to me. well it chokes everytime i put it to neutral. when it starts it idle fine but whenyou drive its crappy. i just adjusted the idle conrtol valve. runs fine for me. Its not a great solution but mines drives perfect lol.
blatour
Car: S13 coupe
bump
srdub-t
Car: white 91 SR22 powered coupe 240sx, 95 black c36 amg
leave the safc plugged in and unplug the maf, see if it idles then. Also check all the settings in your safc.
MastaYu
Car: 92 Nissan 240SX SE HB
new engine =P
danstachet
Car: 90 Coupe, White, SR Powered
i had the same proble. turned out to be a fried injector driver in the ECU...
Start unplugging injector clips while the car is running if you can keep it running to see if unplugging any of them DOESNT make a change... then that means its bad
blatour
Car: S13 coupe
danstachet wrote:i had the same proble. turned out to be a fried injector driver in the ECU...
Where are the clips at? On the ECU? I've never messed with ecus before.
blatour
Car: S13 coupe
Oh, do you mean the clips on the injectors?
So how would I go about getting it fixed? Get a new ecu? I was planning on sending it to enthalpy, would they fix it if it's just a driver?
Hijacker
Car: '92 240sx Convertible
'94 F-150
He means unplug the injectors at the rail. Pull their harness clips off the injector, effectively turning them off. If you pull an injector and the car doesn't start stalling and sputtering, it means that that injector is bad. I have rarely seen an ecu go bad that only took one injector with it, but it can happen.
Also, S-AFCs aren't that great. Someone could have messed with your settings, or it could simply have just gone bad
blatour
Car: S13 coupe
I'm pretty sure its not the safc, because it usually runs and idles absolutely perfect with it unplugged, but when i unplug it now, it still idles good, but theres a bit of hesitation.Time to go freeze some nut hairs/ go find out if its in the safc or ecu.
blatour
Car: S13 coupe
Hijacker wrote:He means unplug the injectors at the rail. Pull their harness clips off the injector, effectively turning them off. If you pull an injector and the car doesn't start stalling and sputtering, it means that that injector is bad. I have rarely seen an ecu go bad that only took one injector with it, but it can happen.
Well it was my SAFC. Thanks for the help!
