dubbs693 »
https://forums.nicoclub.com/dubbs693-u39176.html
Wed Jun 28, 2006 3:44 am
I just recently replaced -O2 Sensor-Battery
She was running rich and wouldn't pass smog so I changed out the parts above and she passed.
Checked spark plugs and on the very tip they are white. I think this means she is running lean.
Typical Day - I start the car after shes been sitting for about 10-12 hours. She sounds good, idles fine. Starting in first is smooth no problems, power is all there and everything. I commute 30 miles one way to work and theres lots of traffic so I'm usually driving for about an hour. I make it to work and the car seems fine. When I come home I make a stop after shes warmed up, start her up again and now when I start off the clutch/flywheel Chatters like a *****. It chirps the tires sometimes. (This doesn't happen when the engine is cold or somewhat warm). Then when I go to hit the gas, maybe half throttle or full (doesn't matter) I get this delay then it takes off then after about 3k to 3.5k I have no power. Its the equivelant to 1/8 throttle and it should be WOT. This happens in every gear except 5th it seems, This can happen either until i get home or sometimes the car "wakes up" after like 30 mins. Then I will have full power again.
It's very wierd and TBH it's driving me nuts!
Also the car bucks around when I get on and off the throttle. Motor/transmission bounce like 2-3 times when I get on and off the throttle. I just replaced motor mounts (nismo). It was really smooth at first then it started bucking. I'm not sure if these 2 issues are related.
Another issue that MIGHT be related. I'm running a 1000 watt rockford amp with a 2 farad cap. Randomly the power will be cut from both the cap and the amp. My driver side window wont work and thats when my car is slow.
I sat down and thought about this with my father, we both have minimal experience with cars. We seem to think it's either the fuel filter, fuel pump, or possibly the MAF. The amp issue I have NO IDEA, All the grounds seem straight.
Let me know what you guys think.. Sorry about the story. THANKS!
