biggie »
https://forums.nicoclub.com/biggie-u182.html
Thu Aug 25, 2005 4:13 am
Air in the system is most likely the problem. Either jack up the front end or use a funnel to get the coolant liquid higher than the rest of the engine. Also use the bleeder screw.
Yes definately change the thermostat (do this anytime you change the coolant), it can get stuck too easily.
Also I'd recommend a water temp gauge, the stock one sucks, and usually by the time you see its even a little hot, then it is way too hot already.
