Car running hot
DRM56
Car: 2011 Infiniti M56s
Hey my fellow owners, I have a 2011 M56 sport. Bout 3 weeks ago my radiator cracked leading to a somewhat expensive repair. While I had it torn down I went ahead and changed the thermostat and spark plugs. Well the past couple of days my car has been running a little hotter than normal, but today it almost ran hot. Makes me believe the water pump could be on it's way out also. Anybody have any ideas or seen something similar?
Ilya
Make sure you don't have air in the system.
satown210
Car: 2012 Infiniti M37
2005 Nissan Xterra Off Road
Did you use an OEM thermostat? Aftermarket thermostats are notorious for failing in Infiniti and Nissans.
Riteoff
Car: 2012 Infiniti M37S
Check, for air in system. Use oem stuff and probably best to service the water pump. Don't over heat you will regret that.
satown210
The waterpump on our engines is not something you service just cause. It is internal and ran by the timing chain. Nissans very rarely have a waterpump failure. It is not impossible but most last the life of the engine.
M56boss
Car: 2011 infiniti M56X
07\08 M45X swap
04 Infiniti FX35
Just had my radiator replaced too and mines started to run a little hot comes to find out the right cooling fan seized got my 56 resting more till I get it fixed
