dvd »
https://forums.nicoclub.com/dvd-u8516.html
Mon Jan 23, 2006 11:17 pm
before swap:*changed piston rings(neighbor changed them who is a mechanic at subaru)*changed headgasket*had head resurfaced*new valve stem seals
I just swaped the ca into my car and it runs really crappy.
* I checked the sparkplugs and 1-3 have black tips(new plugs btw).
So i assumed injector #4 isnt firing because The sparkplug should have been soaked with gas right?
*I brought the injector to a shop and it worked because it was a little bit clogged.*tried to start the car, still sounded crappy.*swaped coilpacks*tested spark with sparkplug tool*checked timing
I tried all those and the car still runs crappy, i tried to drive to but it wouldnt go anywhere, like i was be tryign to gas it but i end up going like 5mph or 10mph constantly. Then when i tried to go up my driveway, i didnt have enough power so it kept dying, only way to get it up was to rev it high and slowly let off the clutch.
I havent checked compression yet, i know there's a leak on the stock coldpipe (on the nipple where it connects to the air regulator, because i can't find a hose small enough that would be securely tight around that nipple.
I really hope its not the compression, i'm going to die or kill myself or something if it is, its been a hectic 1 week and a half now. I'll probalby check the compression but i'm wondering what else is there that i can do?
OH yeah, i hear a loud ticking noise too, no check engine light and i dont have a knock sensor hooked up.
Modified by dvd at 10:42 AM 1/24/2006
Modified by dvd at 10:44 AM 1/24/2006
