del82 »
https://forums.nicoclub.com/del82-u123317.html
Tue Dec 30, 2008 8:37 am
I used to have this problem in a MkIII Supra I had. Mine you could actually *see* the gauge go down if you started hot rodding it in cold weather. Your new thermostat could be a "performance" piece, and by that they just mean its made to operate fully open some 10 degrees cooler or so, but I'd just as soon assume your car has a lot of miles on the engine, produces less power due to wear and therefore less heat, so it's going to have trouble getting up to operating temperature. You may notice a loss in fuel mileage as compared to warmer times, too.
Block off the front of your radiator with a piece of cardboard, or something else that's not likely to melt, and cut a few holes in it about the size of a coke can, see if that helps. You'll probably want to use either zip ties or mechanic's wire to hold it on. If it gets too hot, just make the holes bigger, and don't forget to remove it when the weather starts to warm up again, or if you plan on driving it hard.
P.S. Allowing it to warm up in park for long periods of time isn't necessarily good, and running high RPM on a cold engine can increase the chances of bearing failure, among other things. High RPM under low load also tends to put a lot of combustion gas in the PCV system in worn out engines. Well, high RPM and high load does too, for that matter.
