milto0n »
https://forums.nicoclub.com/milto0n-u172657.html
Mon Apr 30, 2012 11:35 pm
Hi all. I have quite the predicament on my hands. I'll do my best to explain the symptoms. The car turns off and immediately back on while driving. This occurs mostly when hitting bumps on the road BOTH WHILE IN GEAR OR IN NEUTRAL. After to coming to a stop after the car has restarted itself, the car idles much lower and on one occasion has turned off on me once I let go of the brakes. When the car turns off, the headlights will remain on. One more important thing is that the car has ignition kill switch integrated into the alarm system. Searching for this problem has led me to ambiguous answers.
I've tried disconnecting the battery while at idle, car continued to run. I've looked at the driver side wheel well to see if my tires were rubbing and it was fine. The ECU read code 55 so thats fine as well. My next step is to take it the shop that I had the alarm installed and have them temporarily disable the ignition kill portion of my security and see if that is it. Until I can get there, what are other possibilities? Please and thank you.
