hey man thanks alot... im going to work on that today to see if that worksS13FASTBACKSR wrote:you may want to use your afc to take fuel out at that rpm..you are obviously getting too much fuel (hence the black smoke) If you hadnt mentioned that you have an afc that you werent 100% sure of how to work then i would tell you to do an injector test..but right now i think maybe you should figure out first if you have your afc set correctly (if you want to do an injector test to make sure thats not it before you go messing with your afc then pull the spark plugs and if one or two are quite a bit blacker than the others then that spark plugs injector is probably sticking open and putting in too much fuel which will cause richness and misfiring.
