Car pulls to right, restriction on rotor.
vancouverbc
Car: 1991 240sx
Grease the sliding pins. The fact that they move freely is not good enough. steel sliding against steel does not work. it binds. duh.
Terrorinc17
Car: S14
Do all you guys work at Jiffy Lube?
Last question. Di the guy who owns the car do anything to it yet?
theother1wstolen
Car: 92 240sx Coupe SE
terror, seriously, your digging yourself deeper and deeper, he said the tire drags even when the car is on jacks, and your saying its tire pressure or alignment, im sorry, but STFU and GBTW. your an effin retard. sorry guys, it had to be said.
Cone Junky
Car: S13 fastback
BMW e46 328i
theother1wstolen wrote:terror, seriously, your digging yourself deeper and deeper, he said the tire drags even when the car is on jacks, and your saying its tire pressure or alignment, im sorry, but STFU and GBTW. your an effin retard. sorry guys, it had to be said.
I think we should all should just let this one go. Everybody put their 2 cents (and then some) in. So now it is up to the OP to try them or take it to a shop and have them diagnose it. NONE of us can be certain since we can't see, touch, or smell the actual car.
jetroy240
Car: S13, AE86
have you check your rotor ? possible it has run-out or thickness variation or probably warped? try to swap lh to rh rotor, & check if the restriction went to the other side. I'll double check the wheel brg too, u can swap it also lh to rh to check.
vancouverbc
Car: 1991 240sx
The OP should be banned if he doesnt have the manners to report back on what happened. He basically caused a riot by leaving people to speculate.
Terrorinc17
Car: S14
Maybe he fixed it an forgot about us iddiots?
