Car ticking during no start
malik554
Car: 1992 240 s13
So ive been have some problems with my car. At first my car would tick alot when i tried to turn it on so i thought i had a dead battery, then i jump started it and let it charge for a while and instantly after i turned it off it would just tick alot when i tried to start it. so i thought that my battery was done with so i put in a new one. same problem just constant ticking when i tried to start it. then i thought my alternator went bad so i jumped my car and let it sit and unpluged my battery and it still was running so my alternator is good.
Any ideas on what the problem is?
blkvrtswp
Car: 93 240SX Convertible
SR20DET FP 20G Turbo
Most likely loose cables / wires on the battery, alternator and/or starter. Also check the main grounds at the battery tray and on the engine intake manifold.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Take the starter into an advance or parts store and have them test it. Sounds like the starter could be on its way out.
