car problems
sla8ter
Im having trouble with my car. I thought the battery died but i jumped start the car and it started but it only starts if my foot pumps and stay on the gas pedal, if i remove my foot of the pedal it automatically turns off but the lights and everything keep running. Any ideas of what might be wrong?
1) What kind of car
2) Get the codes pulled and report back
Kompresshun
Well first of all, we need to know what kind of car you have. Has it shut down before or have you had to jump it off regularly? It could be an alternator problem in that case. If not its possibly a fuel problem, but we can't really help without some more information.
Welcome to NICOclub!
sla8ter
Its a Jeep Cherokee and this actually the first time i had to jump start it.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
My friend has a 2000 Jeep Grand Cherokee Limited which had a very similar issue. It was very slow to crank and required him to give it gas during cranking, and then stay on the gas or it'd die. It turned out to be a failing battery. Get your battery tested, most parts stores do it for free.
sla8ter
Towncivilian wrote:My friend has a 2000 Jeep Grand Cherokee Limited which had a very similar issue. It was very slow to crank and required him to give it gas during cranking, and then stay on the gas or it'd die. It turned out to be a failing battery. Get your battery tested, most parts stores do it for free.
Thats what i was thinking but wasnt sure. Im definitely gonna have the battery tested and see if thats the main problem.
Kompresshun
Ditto on the battery check. Most of them check the battery and alternator both, which I'm willing to bet one of them are your culprit.
sla8ter
thanks for the replies i appreciate it.
Bubba1
Car: 2003 Nissan 350z
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
sla8ter wrote:. Any ideas of what might be wrong?
Sure, It's a Jeep.... ;) Nah, just kidding. I agree it sounds like the battery, but you also might want to check the fuel filter too, which is inexpensive.
Good luck
300ZXttZMAN
Welcome to nico!
Next time you post try to include more details that way we can help you easier :bigthumb:
