NateDogg »
https://forums.nicoclub.com/natedogg-u710.html
Tue May 03, 2005 8:34 am
When you put new plug wires on, you should always use dielectric grease on the spark plugs and rotate the plug wire boots around so they are easy to get off. I'm not sure if you wrecked that one but just put it back on as best as you can. SOmetimes they don't always fit perfect.
If your engine sounds like it's pulling timing at WOT, you may have a knock sensor malfunction.. You may also have a fuel pump that is not getting enough voltage, causing a lean condition and thus timing retard by the ECU. These are cases that I have seen on the different boards while doing research about my issue, so it's not just a guess.
Do you have any codes?
My problem only happens at part-throttle and I have found a bad MAF reading.
