180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Feb 12, 2005 8:36 am
#1 Yeah that seems pretty normal, I see that on almost all the nissans I work on.
#2 you should check your injector plugs. Mine were corroded and made it very difficult for my injector to pulse and caused my rough idle. Might be worth a shot on your end.
#3 your AC turns off and it'll go back to the way it was like without the AC. See problem #2, a smoother transistion? Probably if you had a smoother running motor.
