s323467 »
https://forums.nicoclub.com/s323467-u18117.html
Fri Jul 16, 2004 12:01 am
Your spayer Should Do The Job, You Only need to add a felx agent to the paint when your painting plastic parts such as the bumbers. When Spaying your basecoats your should not need to wet sand in between coats but you can if you see any drips, dirt, hair, ect. in the base coat you only need to scuff the paint in beetween coats in they are so far apart each other such as a coulple of hours. when spaying your basecoat start with a drop coat that is very light just so the next coats have somthing to stick tothe spay another coat to hide your primer wait ten mins and add coats as necessary.
