trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Tue May 06, 2003 8:59 pm
Yeah I got TOTALLY turned around, I meant make sure the AC condenser is recieving freon, R12 I believe his car uses. I meant to turn on the AC on HOT and see if his heater core might be leaking, if he filled two months ago it might have started leaking during the winter when the heat was on, although if he has checked coolant levels recently this would be a mute point. I would agree with the water pump thing, but a corroded water pump usually shows it when you do a flush. I'm pretty stumped, normal things like rad cap, t-stat, etc, usually fix things like this. I'm boondoggled for sure.......
