s13rb25det wrote:yeah, I thought 120psi was a little low also but that is about average! the specs say 173psi but I have never heard of a rb25det with over 135psi there mostly around 110-125psi and yeah I did it right!! the engine was warm, fuel and spark were disabled, and I held the throttle at WOT. all cylinders were at around 120ish also i show NO signs what so ever of a BHG nothing!!!! I have flushed the cooling system a few times now and put in 50/50 coolant I have a upgraded koyo radiator? I dont know how that could make the car overheat but Im running out of Ideas??!!!!! I will change my waterpump today and also my radiator cap and see what that does!! keep the answers coming in!! thanks Roger
the few ive compression tested are in the 165 neighborhood
mine was 160-165 on all, 120 is NOT normal. try a different compression gauge. but the number isnt important, its the variation from cylinder to cylinder. if they are all within 5-7% usually nothing is wrong unless the compression is incredibly low. i would do a leakdown test on your engine if i got numbers in the 120's.
