rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Tue Sep 27, 2005 5:09 pm
If it overflows into the reservouir, and you are driving around corners (like I am sure you do every day) the magic of centrifical force will pull the fluid to the sides of the reservouir, and out of the crack/hole. When this happens enough, you run low, and the car overheats.
FYI: You would need to do this for weeks on end to dump enough coolant to get a serious overheat. Mine does the exact smae thing, and I have to add about 1/4 cup of coolant to just top it off every week or so.
