jfryjfry »
https://forums.nicoclub.com/jfryjfry-u38277.html
Fri May 12, 2006 4:43 pm
A few clarifications... a lot of the info is good, but just to clear some things up, you *should* use distilled water. it's only about $.99 for 2.5 gallons at the grocery store. it has no contaminents that tap water does. you can use tap water, but it's just not the best. So either way, but distilled water is the best way to go.
And you mix this with antifreeze. 50/50 is a good ratio. you can also add water wetter (or similar). some people swear by it, others have seen no difference.
Lastly, running a car with no water won't instantly damage it. it takes the car a while to get warm enough to damage anything. Drag cars (the fastest ones) don't run any cooling systems. That being said, it isn't a good idea to run the car w/out at least water in it. but don't get too worried that you ran it for a sec w/out water. no biggie.
the factory temp gauges A. suck and B. are usually set conservatively. Meaning that they might not be that accurate and the indicated red zone isn't necessarily the damage zone.
To check that stuff, as has been suggested, do a compression check, and check for water in oil and oil in water. you can also get/rent a tool that detect exhaust in the coolant.
But your problem, ASSuming everything is working properly, is just air in the system. you need to [properly] bleed the system. you can add coolant (properly mixed) while the car is first started up running (read: not hot) if desired.
do a double check of everything -- esp. thermostat and water pump.
