JayEllis wrote:Hello everyone.
First of all, I hope I've posted this in the correct section. Forgive me If I haven't. I'm ok with it being moved to its correct forum section if need be.
Anyways, I own a 03 Infiniti G35. This car has been great to me since I purchased it used from a buddy just over a year ago. It's fulfilled its job quite well, while sparing me any headache. However, just yesterday my car overheated on me. When I got home I inspected its radiator and found that this part was to blame. It showed signs of leakage and a majority of the fins were severely bent. I know that replacement is my only option at this point, but before I do so, I'd like some advice. I've decided to purchase an aftermarket version online, but don't know which companies are reputable. I've found two that I particularly like but before I buy from one of them, I'd like some sort of verification that they are a legitimate business. I almost never buy anything online so I don't know how to spot a scam, and I can't afford to be scammed.
Has anyone dealt with either of the following companies and can verify that they are a legitimate company? The products on the pages have the same OEM number as I’m looking for, so I’m sure they’ll fit my car. Thanks in advance.
http://www.radiatorspot.com/infiniti/g3 ... 03#MjM1NzU
or
http://www.dealerdirectparts.com/Produc ... 5887-G35-2
Welcome to NICO
I've gotten screwed in the past by using independent repair facilities that use aftermarket parts and have a slightly lower labor rate than a dealer.
I no longer use them and only trust the dealer to do work on my G
I would at least get a price from an Infiniti dealer and more than one if you can.
It is not only a radiator that you are dealing with but with an 03 there is the water pump, thermostat, belts, hoses, fans, and radiator cap that may all need to be replaced?
After all of that then a pressure test should be done to prove all is well with your cooling system.
I've learned that buying cheap usually results in buying twice.
Good luck
Telcoman
