silpena »
https://forums.nicoclub.com/silpena-u34788.html
Sun Jul 08, 2007 2:19 pm
I can't figure why 93 240sx over heats? I had a new head gasket replaced (yes i had resurfaced and its completely flat(by 0.012) wapred in the middle.... i blew the head gasket on the water jacket new piston 3....anyway's i put in a new one and a thermostat with a new water pump i had it before the but only had like 50 miles same with thermostat. I acutaly got 2 thermostats and they are nissan oem. I bled the system and came to figure out my radiator was clogged so i had it torn apart and rodded and cleaned out. Bled again and the car was good at idle and good on free way and low 2000 to 1800 rpms but when i run slow like 1,200 then go to 3,000 then back down or stand still for awhile it starts to over heat. ICan't figure out why it overheats still i burped it like crazy and even jacked up. I just bought a new radiator cap cuz my old one worn so i figured thats the only thing left i can replace.... its a 13lb one. You guys think my radiator is still scrwed up? what about the coolant tempature sensor could that be an issue if so then i will replace it. Whats the voltage on it sapposed to be?? i need help i've tried everything! Ithink i might just sell the car, but i love this car,
