S12_hybrid »
https://forums.nicoclub.com/s12-hybrid-u41151.html
Fri Jul 20, 2007 5:54 am
It really sounds to me like you've got your feed wire polaritys switched for your TPS. Think of it this way, its a potentiometer right? So it reads a varying voltage which is delivered by altering resistance.
This may be backwards, i'd have to test a working tps sensor but lets say:
5v = idle (closed plate)0v = WOT
If your polarity was reversed you would read:
0v = idle5v = WOT
This would literally wreack havoc on your ECU.. If would be expecting the engine to be under massive load at idle, and would adjust fueling appropriately (Combined with maf signal, which would just get confusing). When you would go to WOT the engine would attempt to idle - which is why your engine would seem to shut down as modern engines do not inject fuel on over-run.
At least, thats my theory.
-Dan
