lazyazn wrote:Still very confused when I jump the wire and I hear the fuel pump going but when I crank the car it still won't start.
Throwing an engine code at you?
Does it turn over? Does it feel as if it is a battery issue? If so, whoop out the trusty voltometer, have a friend sit in car and tell him to turn the key. Find out what its reading, and I promise, you'll know if its bad.
Check the fuel filter, injectors, anything along those lines. Take the line off one end of fuel pump and hot wire it - see if it spits anything.
Thats all I really got for you for now - answer those questions for me and I'm sure if I can't narrow it down some what, someone will be able to.
