lbrowne »
https://forums.nicoclub.com/lbrowne-u3597.html
Wed Sep 17, 2003 2:36 pm
The neutral safety switch was removed on my 89 before I got it, I can start her without the clutch (better make sure its IN neutral though!)
I'm not sure what to tell you. can you jump start it? LIke get someone to push you down the road, have the clutch in, car in first gear, turn turned forward...once you get enough momentum....pop that clutch out....she if she grabs....
try that?
EDIT: also, if the car was running and you just recently changed those parts.. I'd look for loose/dirty/defective battery terminals, and DEFINITELY take a close look at the starter...the wires n stuff for it.
