car not starting. dont have a clue why.
chea240
Car: 1991 240sx ka24de
ok all i get is a click whenever i try starting it. not the battery. not the starter. i got it checked by two diff. places and its good. i tried jumping the starter and i got nothing except a little winding noise for a second. any advice is appreciated!!!
vancouverbc
Car: 1991 240sx
see tutorial link in my signature. look for starter.
nisssan-drive
Car: 1993 240sx
Check for a button by the clutch pedal. You will actually have to get on your knees to see it and its pretty far left, just look around the top of the clutch pedal and you will find it.If you havent tried or knew this somethimes the peace on your clutch that pushes this button in will break off making you have to push it when you wont to start the car. You have to hold it down of course while you turn over the key this may be the problem.
IrishMadMan
Car: 94 nissan 240sx coupe and 96 mitsubishi eclipse gst
hey guys i have the same problem my 94 auto ka24de coupe overheated on the highway one day coming home from work so i pulled it over and towed it home the next day i went out and put coolant in to and it struggled to turn over so i checked the starter and it was the selanoid so i changed it and it still struggles wtf? any help please
vancouverbc
Car: 1991 240sx
bleed the air out . see coolant tutorial.
[QUOTE=IrishMadMan]hey guys i have the same problem my 94 auto ka24de coupe overheated on the highway one day coming home from work so i pulled it over and towed it home the next day i went out and put coolant in to and it struggled to turn over so i checked the starter and it was the selanoid so i changed it and it still struggles wtf? any help please[/QUOT
chea240
no clutch...its auto...i kno...gayyyyyyyyy!!!lol
chea240
also i dont have an interlock relay box where it shows it in your diagram. i was getting a click and it came from a fuse box on the opposite side of the battery...in the same area as the horn relay, etc.... it said acc on it so i pulled it and it looked fried, so i put a different one in and got nothing???
vancouverbc
Car: 1991 240sx
http://img293.imageshack.us/my...4.jpg
the wiring is complicated for the auto. You have an inhibitor relay. I think it is in the relay box by battery(at least for 1990). You also have an inhibitor switch and auto tran control unit. Get a multimeter and see if you have 12v positive at the starter when you are trying to start.
nisssan-drive
Car: 1993 240sx
Oh... okay my bad man, well conversion coming soon.
Uh... all i could say is do what van said.Check all the wires n ****.Also this is rarely a problem but if the positive and negative wires are really like smudgy looking, try getting some thin sand paper and sand them down could cause it not too not get enough V to start car.Worth a shot good luck.
Modified by nisssan-drive at 11:47 PM 12/21/2007
TotallyStock
Car: 1992 240SX Totally Stock 82k Miles
IrishMadMan wrote:hey guys i have the same problem my 94 auto ka24de coupe overheated on the highway one day coming home from work so i pulled it over and towed it home the next day i went out and put coolant in to and it struggled to turn over so i checked the starter and it was the selanoid so i changed it and it still struggles wtf? any help please
You might want to take a look at the oil on your dipstick. Make sure that you do not see any white or light colored discoloration to the oil. There is a possibility of head gasket failure due to the overheating. It can cause water/coolant to get into the cylinders which can cause the starter to labor against the added pressure of the liquid.
