If that isnt the problem then it could be your temperature sensor. The temperature sensor if bad will tell the ecu that the engine is cold (when it is really hot) and thus the engine will be flooded at crank due to too much fuel being dumped in for "cold" start.lv kaotic wrote:for some reason when my car got really hot it wouldnt make enough volts at my alt.
