YeahJDMracer16 wrote:did it cut off for about 3 or 4 seconds then come back on?
no, your bov should be closed at idle. check the ground wire coming off the coil pack harness. while your at it, check the plugs, coilpacks terminals and the plugs to them. my ground came off and fried the coil pack plug on hte last cylinder. if not, then the mass is the next culprit. if thats fine id put a fuel press gauge on it to make sure its up, while im on the subject, i didnt see a fuel pump in your list of parts.....bad news.240esex wrote:I think my BOV might be leaking.
Your not supposed to be able to feel vaccuum through it, right?
Its closed at idle bet when I rev it just a little it you can feel the vaccuum.srpowered240sx wrote:no, your bov should be closed at idle. check the ground wire coming off the coil pack harness. while your at it, check the plugs, coilpacks terminals and the plugs to them. my ground came off and fried the coil pack plug on hte last cylinder. if not, then the mass is the next culprit. if thats fine id put a fuel press gauge on it to make sure its up, while im on the subject, i didnt see a fuel pump in your list of parts.....bad news.
good luck , keep troubleshooting.
Ticking?240esex wrote:Its closed at idle bet when I rev it just a little it you can feel the vaccuum.
Ill check the plugs tommorow.
And see if the ECU is throwing codes.
BTW fuel pump is a walbro 255. Still using the stock filter though. Ill upgrade to the 300zx filter next time im at an autostore.
Also, lately its been ticking like mad
Typical of a leak somewhere, especially if you are putting out alot of soot in your exhaust from unburnt fuel.240esex wrote:To me it sounds like something under the valve cover. I was told it could be a lose rocker arm. But I have no idea.
It doesnt do it all the time just after its been run for a while or hard.
Also the engine has been cutting out alot when I come to a stop in town. I clutch in/neutral/and glide up to the stop and it will be dead.
And if thats not ****ing enough Im loosing coolant and its not ending up on my pavement.
