SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Sat Dec 03, 2005 8:00 am
Are you useless? Its in the manual.
1) Select sensor type in menu 3 etc. Hot wire 6 in, 6 out. Leave the sensor calibration at 1 in 1 out.
2) Go back to etc, go to Car Select. Select 4 cylinders with the arrow pointing up for throttle type.
3) Make the SAFC self learn the throttle. Floor it for 10 seconds. Then lay off for 10 seconds.
4) Turn off the ignition.
5) Turn on the car and the setting should have been saved. Now you can run the car.
