car not getting gas?
b16acrx1988
alright i have searched all over nico for the answer to this problem but found nothing, i just finished my swap in my 240 and im trying to get it running, it will start up and run for a couple of seconds with starting fluid but it wont stay running, my fuel pump is pumping and it isnt throwing any injector codes, it is throwing codes 2, 3, 4, 5, 10, 20, the only possible thing that i could think of is the fuel rail could be clogged, is there any possible way of checking this without having to take off the whole eccs and injectors, or is there anything that you guys think it could be
89'ClubK's
Car: 89' Nissan 240SX
Perhaps you have bad coil packs and you're not getting the ignition fire you need. Test your packs one at a time, and change your plugs. Make sure the gap is correct. Use some injector cleaner, and if it doesn't pull through, have the injectors tested @ a garage. Maybe an ignitor? Good Luck!
