:help so I got myself another 240sx 89 ka24e model body needs a bit of work but the engine 200kms it runs decent but (smells like burned oil) hmm well here we go blows bluish greyish whitish smoke every time i gas and seems like it leaks power.Also tempts to blow big piles of smoke if i just let it sit and run for 5 minutes and than gas Also i see a bit of oil spills on the side of the block like it comes where head gasket sits.Did some trouble shooting:
Accordin to mechanic there is 3 things that can cause oil burning:1 head gasket,2valve seals,3piston rings. or all 3. Test1 Drained cooling sysytem This is what i found in my block the fluid was redish bbrownish colour with rainbow glow like the one you get when add a drop of oil into water.So mechanic says headgastet is blown and all the passages are ****ed. so all my fluids aren't going where they supose too!:thinker
Soon gonna do compression test to see if piston rins are involed in this mess.
So far mechaniks sad its your headgasket.I am thinkin of tryin this dudes to fix it http://www.thermalweld.com any opinions?
If anyone has any suggestions in regards to my motor pls reply.Thanks
PROBLEM #2
Every time i do right turn or go over spped bump i hear this terrible streching/skratching/grinding noise undernith my rear driverside wheel also it temtst to get louder when it rains and sometimes when it rains I hear that noise when i drive in streight line.:help
So far people sad its your bushing someone sad its power steering?
Which bushing ??? or how do i test if its power steering?
