car might be dead 3rd update / edit bad news
240sxrunner
Car: Auto and Computers
My car has died or something??? ok my timming chain was chattering for a long time and i know it was the tensioner but i dont think that has to do withthe problem. i went out to start the car in the morning to warm it up and i was out for like 5 mins come back my car was off and so i try to start it back up and all it does is turn over. i dont think the chain is broken cause the pulleys still turn if i am thinking right that means it is still on there and working????? need some input and some ideas thanks again guys
for got belts will turn no matter what cause they are connected to the crank not the timming chain
2nd update
the engine is a sohc tonight i am going to take the valve cover off and see if the chain is good i was also thinking that it could be the gas cause i was kinda low on gas but i went i got a two 2 gallon jugs of gas and put it in there and still no start but it could also be that it that the gas is so low that it freezed up in the lines and the tank dont know yet
we will have to see
need more ideas
3rd UPDATED!!!!
took the valve cover off the timming chain was broke in the process it snaped off the sproket off the cam shaft so the cam shaft is broke and the timming chain sproket was down about 5 inches in the engine does not look that bad looks like i will have to fix the cam shaft and the new timming chain and sproket need some input on how much this will all cost to do it my self cause i cant aforrd a sr20 right now help me!!!! i am very sad
MikeMurphy
Car: Guess
maybe some air in the fuel lines?
240SXedUp
It could be alot of things. Bad battery? I had bad battery terminal cables and my car wouldnt turn over, even after i drove it about an hour before.
240sxrunner
help me please
book-ends
Car: ???? Nissan 240SX coupe S13
The only thing I can do is point you in the direction of Courtesy Nissan at:
http://www.courtesy-nissan.com
Check out their on-line parts department for some of the cheapest parts around. They sell timing chain kits that come complete with everything you need for a very good price.
Hope that helps.
