Car Making Occassional Squealing Sound
JaY33s240Sx
Car: 1990 Nissan 240SX
I have a 90 240SX, 5 speed...The problem I'm having is sometimes when I start the car it makes a squealing sound for awhile but eventually stops...There have been times when I am driving and the noise starts and it's a really annoying sound...Anyone know what it might be?? I've been told that it's either the belts need replacing or the pulleys...Please help...:help
navysnail
check your belts, see if they are frayed, cracked or worn, if they are, replace them. make sure they are tight. if that doesn't help, its probobly the pulleys.
slo40
Probably the belt slipping from the alternator kicking on and putting more work and strain on the belt, check the belts and also check to see if oil has gotten on either one. sometimes the power steering fluid will leak and get flung onto the pulley and cause the slippage.
NISTECH
does using the clutch have any effect on the noise?
JaY33s240Sx
No, I don't think the clutch has an effect on the noise...but I did notice that when the noise starts the lights dim on the dash...
MikeMurphy
Car: Guess
alternator!
as mentioned before, check the tension on your belts too.
SunshineAcid
Car: 89 240sx Ka24de swap
definately belts slipping. they may not even be frayed, check tension.
240tek
Car: 89 fastback
Not to jack your thread but I have a similar problem. However, I've narrowed mine down to whenever the heater/ac fan kicks on, it gives me a weird hum/squeal sound. Nothing serious, but it's disconcerting sometimes when it comes on. Sometimes, I'll get the same sound when I depress the clutch. It only happens when I have the air on, either AC or Heat, and the fan is kicking on. Should I be worried? Thanks. PEACE. Tek
240marcuSX
Car: E34 525i
E46 M3
mine does the same thing, but i just replaced my belts not too long ago. It only seems to do it when the motor is cold, And it is sometimes accompanied by another undescribable noise, or the motor will die. Only started doing it since winter came in.
240kid - what do you mean "its probably the pulleys"?? the puleys themselves could have an effect on the noise??
BoyWonder
Car: '93 Nissan 240SX S13 Convertible (reclaimed... wootles)
240tek wrote:Sometimes, I'll get the same sound when I depress the clutch. It only happens when I have the air on, either AC or Heat, and the fan is kicking on.
Could it just be an old fan making the noise? Isn't that called "journaling"(sp)? I know I've seen/heard old non-car fans do something similar IE squeaking sound when they first turn on.
raging panda
Car: s13 coupe
Changing the belts may only solve your problem in the short term, take some simple green to your pullies also and get the little bits of dirt out, then put new belts on. Mine havent squeaked in a year since I've done that.
JaY33s240Sx
thanks for all your professional opinions, i will try them out and let you now the outcome...peace...
