Nope.Dattebayo wrote:Tempered glass with a special coating on it to keep the cubes from spreading out in a crash. We've come full circle now. Are you happy?
lol I admit I should have seen that. One has coating, the other does not. DOH!AZhitman wrote:I won't get into the misinformation about polycarbonate (not "acrylic") housings, lumens / distance requirements, or any of those things.
Seriously, that was the information I had. Got a link?AZhitman wrote:Windshields are generally laminated, not tempered. Side glass is typically tempered, not laminated.
Hope that helps.
Why can't they make glass lenses? Doesn't necessarily have to be a square, sealed beam affair. You can manufacture glass in any shape you want. The only issue, then, would be weight...and that minimal.AZhitman wrote:Easy answer.
I'll give my pathetically weak layman's interpretation, but we should REALLY hit up simmsled, who has been an automotive lighting designer / engineer for damn near a decade.
The Feds mandate the minimum overall front-facing surface area (and rear-facing) of headlights and taillights. The Feds ALSO mandate CAFE standards, which indirectly dictate things like weight and coefficient of drag (in pursuit of compliance with EPA mileage ratings). The Feds ALSO madate pedestrian safety measures.
So, you've got all the engineers working together. The headlight guy wants to use a glass, sealed-beam headlight. However, the physical properties of glass lenses for lights dictate that it needs to be a flat, upright surface (such as an S13 popup headlight). Too heavy. Too drag-inducing. Too dangerous for pedestrians. Not enough illuminating surface area. Not slippery enough. Did we mention it's too heavy? And the coup de grace comes when the "designer" comes in and says, "It's ugly."
Polycarbonate is a fine material for headlight housings if it's maintained.
Lobbyists have successfully killed vehicle inspections in many states, so it;s totally legal to drive around with one dim yellow headlight. I support vehicle inspections, but it's become political - I won't get into WHO opposes vehicle inspections, but suffice it to say, their argument is that it "unfairly penalizes lower income individuals".
Smell what I'm cookin'?
So, Brien, you're not "wrong" per se. But the entities to blame are not who you think they are. You really should get involved in SEMA's Political Action Committee if you care. We do some interesting stuff.
That looks gay anyway. Enough with the cat eyes.AZhitman wrote:<sigh>
On this one, you're gonna have to put on your engineer hat.
Think about it.
Sure, you can replicate that shape in glass. Now, make it thick enough to withstand a pebble striking it at 80mph. And, since it's almost horizontal, it's gonna need to withstand light hail. Now, you need to make sure it'll withstand rapid heating / cooling (such as sitting in 120-degree heat, reaching 180-degrees, and then being hit with 50-degree water from a hose or a car wash).
How thick is the glass on a sealed beam headlight? How do you think that would look (for the design above)? We're talking about a substantial weight increase. You can't make it like a damn wine glass.
Care to share your sources about the light transmission? PC (polycarbonate) is not that different than glass optically. There does appear to be some difference here and there, but what matters most here is in the visible spectrum. So depending on how it was measured and in what form (different applications of glass and plastics may use coatings for specific purposes) each were measured in, its hard to make a direct comparison. That said, PPG's Ultra-clear Glass (I'm assuming that's the product you were referring to) states on their site that the light transmission is 92% in the visible light range. Soda lime glass appears to have about 92% throughout most of the visible range dropping off some as it approaches redder colors:PoorManQ45 wrote:The problems are two fold
1: Ultra Clear glass is capable of 98~99% light transmission. Acrylic maxes around 92%.
I use specialty glass when building flashlights. http://www.flashlightlens.com/str/index ... f=ucl_lensC-Kwik wrote: Care to share your sources about the light transmission? PC (polycarbonate) is not that different than glass optically. There does appear to be some difference here and there, but what matters most here is in the visible spectrum. So depending on how it was measured and in what form (different applications of glass and plastics may use coatings for specific purposes) each were measured in, its hard to make a direct comparison. That said, PPG's Ultra-clear Glass (I'm assuming that's the product you were referring to) states on their site that the light transmission is 92% in the visible light range. Soda lime glass appears to have about 92% throughout most of the visible range dropping off some as it approaches redder colors:
FTFY.Red coupe wrote:Many drivers release gasses that, over time, can build up as a film and cloud windows...
This creates a hazard.
Make it endangered redwoods and so in.Red coupe wrote:Many interior plastics release gasses that, over time, can build up as a film and cloud windows...
This creates a hazard, all car manufacturers should equip their entry level economy cars with solid oak dash boards. To do anything less is negligence.
Probably safety standards, still (and durability). Glass doesn't deal well with rock strikes. I'm sure insurance companies had some say in the matter.PoorManQ45 wrote:I was looking at a 95 Ford e150 van today with foggy lights. What would be the reason for using plastic lenses on vehicles where aerodynamics is not of much concern? Full size vans and trucks mostly.
