Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.html
Wed Aug 29, 2012 10:04 pm
So water drained from the EVAP canister when you removed it from the vehicle with the EVAP canister vent control valve attached? If so, weigh it - it should weigh less than 4 lbs. If it doesn't, check the hose between the EVAP canister and the water separator for clogging or poor connection; if that's fine, you need a new (or junkyard) EVAP canister.
