nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Sun Sep 29, 2013 7:42 am
What did you buy used from a friend? Starter maybe?
Either the battery has a dead cell, which I am putting money on. Or you have very poor connections at the battery and/or grounded to the body causing the issues you have. First and cheapest/easiest thing to do is take the battery out, go get it tested which they should do a load test, that will tell you the health of it.
The fact you said, " ill turn the key to acc and everything will light up without a problem as soon as i turn it to the ignition to start the car you hear the starter do 1 click and then the car will go dead. ill turn the key back and ill only have 8 volts. i put a trickle charge on it over night and itll do the same thing the next day", this tells me the battery have a dead cell. Even though its newer, does not mean its not the problem.
