CAR KEEPS DYING
Xtremist82
Hi, I have a 93 Nissan 240sx Automatic
I dont understand whats going on here... Car runs fine then all of a sudden the car just doesn't do anything... Changed the battery and it works... then 2days later it's dead again.... I even tried to change the ignition switch and still the same problems.... Here's what happens... Nothing cuts on inside the car, lights wont pop up, and a weird clicking sound happens after i pull out the keys and the clock on the hud blinks fast.
Also I've had Autozone check my battery and it was tested good but then wouldn't work. So took another one in the store and it worked... Then it goes as above.... But no signs of the battery dying or any kind of warnings on the hud... just likes to die... anything that I could be possibly missing...
Any ideas please help done spent 340$'s and not any luck....
Modified by Xtremist82 at 9:44 AM 11/22/2006
180fan
Car: 89 fastback
alternator sounds like it's kicked the bucket.
Xtremist82
ok thanks ill check that as soon as i can get back up there to work on it thanks.. much appreciated
dkdeleon68
Car: 1991 240
check your ground wires before replacing anything. always check small and simple thing first.
